Sensors and Transducers: Turbine-Flow Sensor
Feb. 2, 2009
FT-330 turbine-flow sensor, designed specifically for drinking water and beverage-dispensing applications, features a 316 SS shaft coupled with Delrin bearings
The FT-330 turbine-flow sensor, designed specifically for drinking water and beverage-dispensing applications, features a 316 SS shaft coupled with Delrin bearings for accurate measurement during quick dispensing cycles. Constructed with overmolded electronics and lightweight plastic, the sensor can mount in multiple positions. The FT-330 operates in temperatures to 80°C.
Gems Sensors & Controls
One Cowles Rd.
Plainville, CT 06062
(800) 378- 1600
GemsSensors.com
Clean. Compact. Less heat.
April 16, 2025
