New Products: Flexible Coupling
EKH flexible coupling is designed to handle 10,000,000 cycles at rated torque
April 21, 2009
The EKH flexible coupling is designed to handle 10,000,000 cycles at rated torque. A resilient polyurethane insert damps vibration and absorbs slight shaft misalignment in the lateral, axial, and angular directions while transmitting torque free of backlash.
The EKH is available with English, metric, keyed, and smooth bores and handles torque from 15 to more than 19,000 lb-in. Three different inserthardness levels are available for a choice between torsion resistance and flexibility levels.
R+W America
1120 Tower Lane
Bensenville, IL 60106
(630) 521-9911
rw-america.com
