Rear-mount LEDs - Wilbrecht Ledco Inc.
May 12, 2009
The CRM Series of rear-mount LEDs lets users remove the LED from a panel without removing terminations. The LED’s nickel-plated brass housing has a flat side to prevent rotation when mounting. The indicators secure to front panels with a nickel-plated-brass hex nut. The LEDs, fitted with dual nitrile O-rings, are internally potted to IP66, making them suitable for high-vibration applications. The indicators feature 20 ±2 lb-in. mounting torque; 10-lb pushout force; and daylight-readable single-color LEDs that are also available as bicolor, tricolor, full-color RGB, and blinking. Internal resistors for 5 to 60 Vdc or 120 Vac with LED pin terminations or insulated wire leads are available.
Wilbrecht Ledco Inc., 1400 Energy Park Dr., Suite 18, St. Paul, MN 55108, (888) 323-8751, wilbrechtledco.com
