New Products: Linear-Motor-Driven Actuator
The P3 linear-motor-driven actuator is designed with the linear-motor coil integrated into the top assembly plate for optimized thermal conductivity.
May 19, 2009
The P3 linear-motor-driven actuator is designed with the linear-motor coil integrated into the top assembly plate for optimized thermal conductivity. This design provides high stiffness/low cogging for extremely smooth constant-velocity motion even at low speeds.
Features and benefits of the actuator include high speed and acceleration — up to 5 m/sec @ 10 g; two encoder options for high resolution and low cost; alternate motor selections for different load requirements; ironless linear motor for zero cogging and smooth motion; integrated cablehandling system; and travel lengths to 1 m.
The system offers two encoder feedback options. The magnetic encoder provides clean quadrature signals for difficult environments from 1 to 5-μm resolution. The optical encoder provides resolution at 0.5 and 0.1-μm resolutions.
Schneeberger Inc.
11 DeAngelo Dr.
Bedford, MA 01730
(781) 271-0140
www.schneeberger.com
Contributors:
