New Products: Disc-Brake Calipers
Spring-applied, hydraulically released VKSD Model disc-brake calipers are used for emergency stops
June 16, 2009
The spring-applied, hydraulically released VKSD Model disc-brake calipers are used for emergency stops, for normal stopping and parking, at junctions where one conveyor feeds material to another (at risk of overspill), or where there is risk of personal injury, particularly in underground mining.
The brakes may be fitted to the tail drum, driving drum, or motor shaft. For long overland conveyors,the VKSD should be fitted to the upstream end to prevent a catapult effect due to reversal of belt tension. These brakes are suitable for winder and haulage applications.
Twiflex, Alta Industrial Motion
300 Granite St.
Braintree, MA 02184
(800) 964-3262
www.twiflex.com
