Miniature Single and Dual-Channel Incremental Encoders
Designated as the OPE1275 singlechannel (tachometer) and OPE2275 dual-channel encoders, these analog output encoders are designed for small-shaft motors with a shaft diameter of 2 mm (0.079 in.) and a minimum length of 3.8 mm (0.150 in.)
