Heavy-duty priority flow-control valves provide a simple and efficient way to supply auxiliary hydraulic power to mobile work tools and attachments, such as hydraulic impact hammers, compactors, saws, and cold planers.
Heavy-duty priority flow-control valves provide a simple and efficient way to supply auxiliary hydraulic power to mobile work tools and attachments, such as hydraulic impact hammers, compactors, saws, and cold planers. Valves can be added to existing systems without modifying a machine’s directional-control valve. Also called “hammer valves,” they are available for single pump, double pump, or load sensing. The valves feature zinc-plated steel bodies, IP69-rated coils, and three-way configuration: one pump inlet port and two outlet ports for priority and bypass flow. Bosch Rexroth, 2315 City Line Rd., Lehigh Valley, PA 18002, (610) 694-8298, www.boschrexroth-us.com/brh-m
