The mini MV micro valves offer short cycle times, low-energy consumption, and high reliability. The electrically actuated 3/2 pneumatic valves screw directly onto the actuator, making hose connections between the valve and the actuator unnecessary, reducing interfering contours and assembly expense. Airflow and air connection threads are specified exactly for the relevant actuator. The maintenance-free valves take just 7 msec to switch, and have a 900 million switching-cycle lifespan.
The micro valves come in 1.5, 2.5, and 3.0-mm sizes and achieve a flow rate of 2, 5, and 9-cfm at 87 psi.
Schunk Inc.
211 Kitty Hawk Dr.
Morrisville, NC 27560
(800) 772-4865
www.schunk.com
