Braid-reinforced hose - NewAge Industries Inc.
Flexible Silbrade silicone hose, designed for fluid-transfer applications, can also be used as protective jacketing.
 Flexible Silbrade silicone hose, designed for fluid-transfer applications, can also be used as protective jacketing. The braid-reinforced hose — open mesh polyester braiding incorporated within walls of silicone tubing — handles high-pressure applications and steady or fluctuating temperatures between –80 and 350°F. The braided construction allows excellent bend radii and restricted space usage without impeding flow. The peroxide-cured Silbrade is manufactured in a controlled environment for cleanliness. The hose is available in nine sizes from 1/8 through 1-in. ID, or through custom order, which includes cut-to-length pieces, colors, and hardnesses.NewAge Industries Inc., 145 James Way, Southampton, PA 18966, (800) 506-3924, www.newageindustries.com/slbrd.asp RS# 449
