High-performance BLDC motor -- BEI Kimco Magnetics
 The high-performance Size 23 BLDC motor features a customized housing and shaft. Its standard high-torque density design (P/N DIH23-30-BFNA) delivers continuous power at levels approaching 1-hp continuous at speeds up to 20k rpm. The unit measures 2.3-in. OD × 3.0 in. in length with operating efficiencies in excess of 85%. The motor meets requirements for a cast-removal system that reduces pediatric-patient trauma.BEI Kimco Magnetics, 2470 Coral St., Bldg. D, Vista, CA 92081, (800) 572-7560, www.beikimco.com
