Stainless-steel bushings -- Graphite Metallizing
A new series of Graphalloy self-lubricating bushings mounted in stainless-steel flange blocks.
 A new series of Graphalloy self-lubricating bushings mounted in stainless-steel flange blocks combines the corrosion-resistant and self-lubricating properties of Graphalloy with the versatility of a flange block.The bushings are available in two and four-bolt configurations in a wide range of base dimensions. They accommodate shaft diameters from 0.5 to 3.75 in. and are suitable for temperatures of 750˚F and above in nonoxidizing environments or with oxidation-resistant grades.Graphite Metallizing, 1050 Nepperhan Ave., Yonkers, NY 10703, (914) 968-8400, www.graphalloy.com
