Spiral wire hose -- Eaton Corp.
The Aeroquip GH810 Ice Champion hose is engineered for low-temperature, high-pressure hydraulic applications.
 The Aeroquip GH810 Ice Champion hose is engineered for low-temperature, high-pressure hydraulic applications. The spiral-wire hose handles temperatures down to –67°F at operating pressure to 6,090 psi.The hose comes in –12 through –24 sizes and uses Aeroquip global Spiral TTC crimp fittings, which require no skiving. With a 4:1 safety ratio, the hose withstands 400,000 impulse cycles.Eaton Corp., Hydraulics Group USA, 14615 Lone Oak Rd., Eden Prairie, MN 55344, (952) 937-9800, www.eaton.com/hydraulics
