Thermal-conductive epoxy - Master Bond Inc.
EP21TCHT-1 is a rigid, room-temperature-curing thermal-conductive epoxy with a service-temperature range of 4K to 400°F.
Feb. 18, 2010
EP21TCHT-1 is a rigid, room-temperature-curing thermal-conductive epoxy with a service-temperature range of 4K to 400°F. It has high thermal conductivity, superior electrical insulation properties, and low thermal-expansion coefficient, making it suitable for low outgassing applications and use in vacuum environments.
EP21TCHT-1 has a mix ratio of 100 to 60 by weight, high physical strength properties, and a light-paste viscosity. It adheres to metals, ceramics, woods, vulcanized rubbers, and most plastics. Bonds are resistant to water, fuels, and most organic solvents.
Master Bond Inc., 154 Hobart St., Hackensack, NJ 07601, www.masterbond.com
