Pneumatic pressure transducer - Gems Sensors & Controls
The new 3300 Series pressure transducer, designed for low-pressure applications.
The new 3300 Series pressure transducer, designed for low-pressure applications, features all-stainless-steel wetted parts and all-welded construction for use with harsh chemicals and environments.The transducer is available in 15 to 250-psi pressure ranges; operates in –40 to 257°F; and is available in voltage, current, and ratiometric outputs.Gems Sensors & Controls, One Cowles Rd., Plainville, CT 06062, (800) 378-1600, www.gemssensors.com
