Gearmotor/brake-Midwest Motion Products
The Model No. MMP-D22-376H-24V GP52-195 BR-005-IP54 dc gearmotor, with an integral brake, features high-efficiency planetary gearing.
The Model No. MMP-D22-376H-24V GP52-195 BR-005-IP54 dc gearmotor, with an integral brake, features high-efficiency planetary gearing, high-output  torque to size and weight ratio, and low speed and noise.
The motor accepts any 24 Vdc source, including battery power, while consuming only 375 mA of current. The totally enclosed brake mounts to the rear of the motor, creating an IP54-sealed assembly. The brake measures just 2.25 × 9.0-in. long, and has a keyed output shaft of 12-mm diameter × 25-mm long. Easy mounting is accomplished with four “face-mount” M5 threaded holes.
Midwest Motion Products, 10761 Ahern Ave. SE, Watertown, MN 55388, (952) 955-2626, www.midwestmotion.com
© 2010 Penton Media, Inc.
