Extra-large cable glands - Sealcon
Hummel WADI-XL cable glands accommodate cable ranges of 1.89 to 3.54 in.
July 8, 2010
Hummel WADI-XL cable glands accommodate cable ranges of 1.89 to 3.54 in. The glands are available in metric (M63, M75, M80, M90, M100, M110) and BSPP (British standard pipe parallel) thread (G2 ½-in., G 3-in., and G 4-in.) sizes. The M63 enlarged version with a cable range of 48 to 55 mm (1.89 to 2.17 in.) and additional sizes M75, M80, M90, M100, and M110 come with different seal materials, depending on application needs. Nickel-plated brass for oily environments is available. For outdoor applications and saline environments, the HSK-XL fittings can be equipped with an EPDM seal. Silicone (for high or low temperatures) or Viton are available for applications requiring chemical resistance.
Sealcon, 14853 E. Hinsdale Ave., Suite D, Centennial, CO 80112, (800) 456-9012, www.sealconusa.com
© 2010 Penton Media, Inc.
