Safety-screen adapter - The Lee Co.
The 5k flareless-tube safety-screen adapter incorporates a solid stainless-steel Hi-Bar safety screen in a new ring-locked adapter.
The 5k flareless-tube safety-screen adapter incorporates a solid stainless-steel Hi-Bar safety screen in a new ring-locked adapter. The adapter withstands pressures to 5,080 psi, compared to traditional flareless-tube adapters, which are rated for 4000 psi. After the screen is installed into a lightweight titanium fitting, it is 100% proof-pressure tested.
The adapter is available in –4, –6, –8, and –10 configurations, and in hole sizes ranging from 0.002 to 0.020 in. in diameter.
The Lee Co., 2 Pettipaug Rd., Box 424, Westbrook, CT 06498, (860) 399-6281, www.theleeco.com
© 2010 Penton Media, Inc.
