Data-acquisition instrument-Dewetron Inc
The DEWE-50-USB2-8 is a USB-based data-acquisition system with plug-in signal-conditioning modules for low and high voltages, strain, pressure, acceleration, sound, temperature, and force.
The DEWE-50-USB2-8 is a USB-based data-acquisition system with plug-in signal-conditioning modules for low and high voltages, strain, pressure, acceleration, sound, temperature, and force. The unit’s digitizer features eight separate 24-bit ADCs — one per analog channel — for simultaneous sampling of all channels with very-high resolution on the vertical axis. This also permits the use of a single gain setting for widely varying signals. Any combination of eight DAQP Series plug-in modules plug into the unit’s front, while the rear panel provides two synchronous counter inputs; two high-speed CANbus interfaces; and the dc power input connector, as the system runs from 10 to 30 Vdc directly (ac/dc adapter and line cord included).
Dewetron Inc., 10 High St., Suite K, Wakefield, RI 02879, (401) 284-3750, www.dewamerica.com
© 2010 Penton Media, Inc.
