Pneumatic solutions
Locking slide cylinder Non-rotating, high-powered thruster achieves strokes to 20 in. Features & benefits One-piece end caps house twin 2 in. bore cylinders
Features & benefits
  • One-piece end caps house twin 2½ in. bore cylinders for power
  • Eliminates deflection or drift within cylinder bodies
  • Locking mechanism keeps cylinder in extended position in case of air loss
Numatics
Mount Pleasant, Tenn.
(615) 771-1200
www.numatics.com
Circle 199
Two-stage telescoping cylinder
Double-acting, 2-stage telescoping cylinder requires less space than other cylinders.
Features & benefits
  • Rated for pressures to 125 psi with ¾, 1½, and 2½in. effective bore sizes
  • Strokes to 60 in.
  • NFPA-mountable
  • Made of anodized aluminum; stainless steel optional
TRD Manufacturing Inc., a Bimba Co.
Machesney Park, III.
(815) 654-7775
www.trdmfg.com
Circle 200
Rolling diaphragm cylinders
Diaphragm air cylinders provide frictionless conversion of pneumatic pressure to linear force.
Features & benefits
  • Lack of stiction or blow-by ensures accuracy, repeatability, and sensitivity
  • Available in strokes of 1.8 to 4.2 in.
  • Rated for pressures to 145 psi and temperatures of -75° to 400° F
ControlAir Inc.
Amherst, N.H.
(603) 886-9400
www.controlair.com
Circle 201
