Product Spotlight: Ac drives
Inverters
X200-series inverters deliver power and flexibility in a compact contactor-style package.
Features & benefits
Power input at top, motor output at bottom of unit
UL, c-UL, CE, and C-certified; RoHS compliant
Safe Stop provides hardware-based emergency stop
Decelerate and stop motor using regenerative energy from the load when ac supply power is lost
Trip avoidance and automatic energy saving function, built-in timing logic, analog input math (PLC) functions, and RS485 Modbus/RTU communication interface
Hitachi America, Ltd., Industrial Systems Div.
(914) 631-0600
www.hitachi.us/inverters
Circle 151
RoHS-compliant ac drives
V1000-series ac drives feature maintenance monitors to ensure drive health, on-line tuning to maintain harmony with motor, and application presets for easier installation.
Features & benefits
Suitable for ⅛ to 25 hp motors
Three models — 200 to 240 V single-phase, 50/60 Hz; 200 to 240 V three-phase, 50/60 Hz; and 380 to 480 V three-phase, 50/60 Hz
Stackable side-by-side, due to heat-sink technology
Vector control, open loop
Standard EN954-1 Safety Category 3 safety input to disconnect the motor
Yaskawa Electric America Inc.
(800) 927-5292
www.yaskawa.com
Circle 152
Variable speed ac drives
X5 UltraFlex ac drives are enclosed for high performance in demanding applications and are easy to set up and maintain.
Features & benefits
- Up to 200 hp
- Real-time clock
- Supports most popular communication protocols
- Offer encoder feedback capabilities and a USB port
TB Wood's Inc., an Altra Industrial Motion company
(888) 829-6637
www.tbwoods.com
Circle 153
Modular drives
AC890PX modular ac drives feature pluggable power modules for quick replacement and reduced downtime.
Features & benefits
600 hp and 380 to 690 Vac ratings
Communicates with all protocols, including Ethernet, ProfiBus, ControlNet, DeviceNet, CanOpen, and Firewire, with available option cards
Run induction, torque, and permanent magnet servo motors in control modes including simple V/Hz, open-loop flux vector, and precision closed-loop vector with positioning
Come with disconnect fuses, a harmonic reducing input line reactor, and dynamic braking resistor
Parker Hannifin Corp., SSD Drives Div.
(704) 588-3246
www.parker.com
Circle 154
Vector drives
SMVector advanced inverter drives feature expanded communication options, including RS-485/Modbus, CANopen, and DeviceNet.
Features & benefits
Up to 25 hp; input voltage from 120 Vac, 1-phase to 600 Vac, 3-phase
Four operating modes — V/Hz, enhanced V/Hz, vector speed, and torque
Pop-in communication modules can be installed upon order or inserted into existing SMVector
Electronic programming module removable memory chip allows quick and easy programming
AC Technology, a member of the Lenze Group
(508) 278-9100
www.actech.com
Circle 155
