Product Spotlight: Ball/leadscrews
Leadscrews
Non-ball leadscrews can self-lock and prevent back driving, without an external brake, unlike traditional ballscrews for vertical applications.
Features & benefits
- Sliding friction between nut and screw converts rotary input motion to linear output motion, for accuracy comparable to ground ballscrews
- No need for hardening; easily machined
- Proprietary coating eliminates need for external lubrication and maintenance
- Manufactured from 303 stainless steel with precision rolling process
- Standard diameters from ⅛ to 15/16 in.; standard leads from 0.02 to 3 in.
Kerk Motion Products Inc.
(603) 465-7227
www.kerkmotion.com
Circle 153
Ballscrews
Long-lead ballscrews with a rotating nut design provide precise positioning and serve as compact, ready-to-use, and easily integrated solutions for linear-actuation applications requiring high speeds, low noise, and long strokes.
Features & benefits
Design allows drive motor to move with the nut to reduce inertia, require less power, and achieve linear speeds to 110 m/min.
Integrated nut minimizes inertia and critical-speed problems
Series SLT features nut with axial play; series BLT offers backlash elimination
Diameters range from 25 to 50 mm; leads range from 20 to 50 mm
Options include double protection wipers and brush wipers in cylindrical and flanged nut configurations and long-lead screws
SKF USA Inc.
(800) 541-3624
www.linearmotion.skf.com
