New Products
Self-lubricating slewing rings PRT slewing ring bearings use two self-lubricating, low friction polymer sliding elements in place of ball bearings. Features
Features & benefits
  • Polymer sliding elements of solid lubricant requiring no additional lubrication
  • Low coefficient of friction, chemical resistant, low moisture absorption, and good vibration dampening properties
  • Consist of aluminum housings with stainless steel screws
  • Available with ODs of 30, 60, 100, and 200 mm
igus Inc.
(800) 521-2747
www.igus.com
Circle 160
Programmable cameras
BOBCAT line of machine-vision cameras in 45 × 45 × 39-mm envelope offer advantage where space is limited.
Features & benefits
  • Easily replaces existing analog units, field-upgradeable firmware
  • Choice of five resolutions and sensors: Kodak VGA @ 120 or 210 fps; Sony 1.4 M @ 24 fps, 2.0 M @ 16 fps, and 5.0 M @ 15 fps
    Horizontal and vertical binning at 2x, 3x and 4x from the factory, multiple programmable areas of interest, digital and analog gain
  • Auto gain, exposure control
Imperx Inc.
(866) 849-1662
www.imperx.com
Circle 161
Parallel grippers
EGN series of servo electric two-finger parallel gripers now include sizes 80, 100, and 160.
Features & benefits
  • Stroke per finger of 8 and 16 mm
  • Upward and downward expansion allows the exact size gripper for each task with the right specifications
  • High payloads and power reserves handle heavy components with gripping forces to 1,000 N
  • Prepositioning enables short closing times and high cycle rates
Schunk Inc.
(800) 772-4865
www.schunk.com
Circle 162
Ethernet connectors
RJ-45 modular plug and jack connectors offer IP67 sealing and quick-connect bayonet coupling suited for EtherNet/IP, DeviceNet, and ControlNet applications.
Features & benefits
  • Coupling mechanism provides positive locking for reliable connections in harsh environments
  • Housings are polarized to prevent mismatching
  • Plug kits available for stranded and solid conductors; bulkhead-mount receptacle permits pass-through applications
Tyco Electronics Ltd.
(800) 522-6752
www.tycoelectronics.com
Circle 164
Roller chain
PerforMax bushings offer roller chain improvements with upgraded performance and reliability.
Features & benefits
  • Lube grooves, heat treatment, and precise dimensions produce a solid bushing
  • Designed grooves extend life by combating wear
  • Available in sizes 80 to 140
U.S. Tsubaki Inc.
(800) 323-7790
www.ustsubaki.com
Circle 163
Sensors
Uprox + Factor 1 sensors now include IP69k washdown versions with temperature ratings from -40° to 100° C.
Features & benefits
  • 316 stainless steel construction, liquid crystal polymer front cap resist moisture
  • Polypropylene cable jacket stands up to harsh chemicals, extreme temperatures
  • Longer sensing ranges detect all metals including stainless steel
TURCK Inc.
(800) 544-7769
www.turck.com
Circle 165
Accelerometers
Signal-conditioned accelerometers provide stable vibration measurement outputs over wide temperature range.
Features & benefits
  • Dc response accelerometers offered from ±2 to ±500 g
  • Integral temperature compensation provides output from -40° to 115° C
  • Gas-damped MEMS sensing elements for stable frequency response
  • Hermetically sealed assemblies protect against over-range shocks up to 10,000 g
  • Programmed for exceptional thermal stability and recalibrated for different signal outputs and scale factors
Measurement Specialties Inc.
(949) 716-7516
ww.meas-spec.com/vibration
Circle 166
Protective boots
Protective boots stop rod scoring, prevent nicks, and extend seal life by protecting cylinder rods from chips, abrasive particles, and impinging objects.
Features & benefits
  • Neoprene nylon coated fabric boots handle temperatures from -40° to 220° F
  • Materials for expanded temperature ranges and special requirements available
  • Request catalog PR-100
A & A Mfg. Co. Inc.
(800) 298-2066
www.gortite.com
Circle 168
PC belt
Pyrathane twisted connectable PC belts are now available to replace endless belts in diameters from 3/32 to 9/16 in.
Features & benefits
  • No disassembly when replacing belts on line shaft conveyors and other applications
  • Originally designed as quick fix, but now a permanent replacement in many applications
  • Available in standard black 83A durometer
  • Other colors and durometers available
Pyramid Inc.
(641) 792-2405
www.pyramidbelts.com
Circle 169
Step motor driver
DRV-1 is a 1 amp, microstepping driver suitable for a range of resolutions.
Features & benefits
  • Six resolution settings from full to 1/32 step
  • Includes small (2.7 × 3.1 × 1.0 in.) heat-sink mounted footprint, 31.25 kHz step clock, over current protection, and mating connectors
  • Factory programmable for plug and play operation of up to four user-determined constant velocity motion profiles
Advanced Micro Systems Inc.
(800) 234-2001
www.stepcontrol.com
Circle 167
Transport system
MagneMover shuttle combines the QuickStick LSM product line with standard aluminum track and vehicle components for flexible turnkey transport.
Features & benefits
  • High-speed transfer shuttle allows a range of system layouts; tightly spaced return paths save floor space
  • Moves carriers at faster speeds and accurately positions loads to facilitate on-carrier work processes and higher throughput
  • Carriers can be stopped anywhere along the transport track; location can be changed in a few computer keystrokes with no mechanical parts or adjustments
MagneMotion Inc.
(978) 461-5090
www.magnemotion.com
Circle 170
Brushless servomotor
BSM132 high-power brushless servomotor ranges from 20 to 34 hp with optional blower cooling.
Features & benefits
  • Continuous stall torque from 620 to 1,060 lb-in. and speed capability to 5,000 rpm
  • Double insulated, multicoated magnet wire for reliability
  • Premium grease provides four times longer life
  • Quality servo-rated ball bearings offer durability and smoothness
  • Sealed to IP65
Baldor Electric Co.
(479) 646-4711
www.baldor.com
Circle 171
