Pneumatic SOLUTIONS
Rodless cylinders
GSU (guided slide unit) pneumatic linear drive can be used in gantries as an X-axis or as a workpiece pallet in material supply.
FEATURES & BENEFITS
- Speeds to 1.5 m/sec for short cycle times
- 16 and 25 mm bores
- High rigidity and precise slide guiding
- Adjustable end stops for multiple positions with single unit
- Air connections on sides or front
BOSCH REXROTH CORP.
Lexington, Ky.
(859) 254-8031
www.boschrexroth-us.com
Circle 183
Pneumatic grippers
GRR Guardian grippers provide high grip force in long jaw travels of 150, 200, 250, and 350 mm.
FEATURES & BENEFITS
- Withstand high impact and shock loads
- Double acting for internal and external gripping
- Dual air-passage piston rod design allows rapid bore pressurization for fast cycle times
- Synchronized, non-synchronized, or non-synchronized with independently powered jaws
PHD INC.
Fort Wayne, Ind.
(260) 747-6151
www.phdinc.com
Circle 184
Industrial shock absorber
MC 30M-Z miniature industrial shock absorber mounts into pneumatic cylinders and rotary actuators with a stretch seal design for high-energy absorption in confined spaces.
FEATURES & BENEFITS
- Impact velocity range of 2.2 to 12.9 ft/sec
- Operating temperature of 32° to 150° F
- Integral mechanical stop built into front
- 31 lb-in./cycle energy, 0.57 to 1.56 lb return force
ACE CONTROLS INC.
Farmington, Mich.
(248) 476-0213
www.acecontrols.com
Circle 185
Stainless steel cylinders
Pneumatic cylinders feature polished stainless steel tubes with ID 304 for low friction.
FEATURES & BENEFITS
- 12 bore sizes with strokes to 40 in.; full metric line offered
- Maximum pressure of 250 psig
- Precision-rolled construction, clear anodized machined aluminum heads, and roller burnished 303 stainless rods for long life and performance
- Threaded rods bonded to pistons and Buna-N U-cup rod seals
CLIPPARD INSTRUMENT LAB INC.
Cincinnati, Ohio
(888) 439-6264
www.clippard.com
Circle 186
