Product SPOTLIGHT
Modular step motor
The 3509V is a 0.9°, size-14 step motor with five mounting options.
FEATURES & BENEFITS
- 1.5 arc minutes accuracy
- 0.82 × 1.44 in. square, 0.27 lb
- Holding torque 16 oz-in.
- Windings encapsulated with thermally conductive ceramic-based polymer
LIN ENGINEERING
Santa Clara, Calif.
(408) 919-0200
www.linengineering.com
Circle 134
Mini servodrives
Servodrive family expands to cover low-power range from 450 to 700 W.
FEATURES & BENEFITS
- 2.3 × 8.1 × 8.7 in.
- 100% compatible with existing series
- Integrated braking resistor, line filter, restart inhibit, and motor holding brake control
B&R INDUSTRIAL AUTOMATION CORP.
Roswell, Ga.
(770) 410-3206
www.br-automation.com
Circle 135
Five axis stepper module
The new Five Axis Integrated Stepper Module (FAISM) directly controls up to five stepper motors.
FEATURES & BENEFITS
- Includes stepper translator, output connects directly to the stepper motor
- Five channels of SSI encoder feedback available
- Profiles set up through the main control's application program using PiCPro for Windows
G&L MOTION CONTROL LLC
Fond du Lac, Wis.
(920) 921-7100
www.glcontrols.com
Circle 136
Compact servodrives and motors
The new Allen-Bradley Ultra 1500 servodrives and TL-Series servomotors are easy-to-use and compact in design.
FEATURES & BENEFITS
- Four frame sizes
- Includes diagnostic and troubleshooting tools
- Feedback resolution greater than 100,000 counts/rev
- Continuous stall torque of 0.096 to 5.42 Nm (0.55 to16.4 lb-in.)
ROCKWELL AUTOMATION
Milwaukee, Wis.
(800) 223-5354
www.rockwell.com
Circle 137
Hybrid stepper motors
New MAE “N Series” hybrid stepper motors feature neodymium magnets for maximum torque and superior acceleration.
FEATURES & BENEFITS
- NEMA frame size 34 (lengths 2.64, 3.70, 4.92 in. with holding torques of 397 oz-in., 680 oz-in., 1,076 oz-in.)
- NEMA frame size 42 has holding torques of 1,204 oz-in.
- Step resolutions of 1.8° (200 steps/rev)
- Precision-honed stators and ground rotors, 4,6, or 8 leads, single or double-ended shaft extensions
PENNENGINEERING MOTION TECHNOLOGIES
Harleysville, Penn.
(877) 748-8626
www.pennmotion.com
Circle 138
Driver-controlled servomotors
Motor models BS 80/50 through BSE 80/100 deliver from 450 to 900 W, and are controlled by their own drivers.
FEATURES & BENEFITS
- 15 inputs and eight outputs (digital)
- Two inputs and two outputs (analog)
- One input/output for simulation or encoder tracking
MINI MOTOR
www.minimotor.com
Circle 139
Stainless steel servomotors
This new Stainless Steel ServoMotor (SSBSM Series) was designed with durability in mind.
FEATURES & BENEFITS
- Handles IP67 and 1,500 psi washdown conditions
- Standard and low inertia models
- Five frame sizes
- Continuous torques to 280 lb-in. (32 N-m) with up to 400% peak torque continuous
BALDOR ELECTRIC CO.
Fort Smith, Ark.
(800) 828-4920
www.baldor.com
Circle 140
Synchronous servomotors
DT series of synchronous servomotors provides maximum power in a very small frame.
FEATURES & BENEFITS
- 30 kW power output
- Maximum torque 600 Nm
- Suitable for applications with intermittent operation
AMK DRIVES & CONTROL INC.
Richmond, Va.
(804) 222-0323
www.amkdrives.com
Circle 141
Slotless motors
Slotless HO Series Brushless Servomotors are ideal for light assembly and inspection applications.
FEATURES & BENEFITS
- Less than 1% harmonic distortion
- Eliminates magnetic disturbances
- 29 million counts/rev with a repeatability of 0.3 microradians
- 16 mm through bore (hollow shaft)
APPLIMOTION INC.
Loomis, Calif.
(916) 652-3118
www.applimotion.comCircle 142
Miniature programmable servo
Thumb size EZServo controller and driver is fully programmable and fits on the back of a HEDS 5500 Encoder (1.4 × 0.95 in).
FEATURES & BENEFITS
- Controls a DC Brush Motor at 1A, 50V with Quadrature Encoder Feedback and operates in Position, Velocity or Torque modes
- Communicates with a host computer via the RS232/485 standard serial interface
- Simple text-based commands control operation
- Minimal wiring uses a four wire bus (2 power 2 communications) to daisy chain up to 16 EZServo and/or EZStepper controller + drivers.
ALLMOTION
San Jose, Calif.
(408) 460-1345
www.ezservo.com.
Circle 143
