Proportional valve CD
An introductory CD highlights the features and specifications of EVP proportional-control valves.
FEATURES & BENEFITS
- Control air and gas flow, varying flow by changing solenoid current
- Consistent gain provides high accuracy
- Controlled with dc current and pulse-width modulation, open or closed loop, in a broad range of applications
CLIPPARD INSTRUMENT LABORATORY INC.
Cincinnati, Ohio
(888) 439-6264
www.clippard.com/evp-h
Circle 239
Modular pneumatic actuators
Line of short stroke pneumatic actuators is offered in modular configurations where multiple units are integrated into a single housing.
FEATURES & BENEFITS
- 25 to 175 lb thrust force with standard plant air input
- 0.1 to 2 in. stroke lengths
- Operates on standard four-way valve circuits for individual or simultaneous motions
- Provides several independent axial forces
MACK CORP.
Flagstaff, Ariz.
(928) 526-1120
www.mackcorp.com
Circle 240
Pneumatic hoses
Chainflex Air pneumatic hoses are designed for use in an Energy Chain System and are resistant to abrasion, oil, and coolant.
FEATURES & BENEFITS
- Tested for more than 10 million cycles at a bend radius 10 times the outer diameter
- Durable polyurethane construction
- More than 10 sizes available
IGUS INC.
East Providence, R.I.
(401) 438-2200
www.igus.com
Circle 241
Air cylinders
NR series stainless steel air cylinders are designed to maximize performance, and come with stainless steel piston rods, roll-formed threads at both ends of the piston, and pre-lubrication.
FEATURES & BENEFITS
- 5/16 to 3 in. bore sizes
- Up to 32 in. stroke length
- 250 psig
- Adjustable cushions and single and double rod
- Standard temperatures of -10° to 165°F
AIRCYLINDERSDIRECT.COM
(866) 404-5300
www.aircylindersdirect.com
Circle 242
