Pneumatic solutions
Pneumatic valves, FRLs
Maximatic valves, FRLs, and components can be used in packaging, assembly, and manufacturing.
Features & benefits
Available as 3-way, 4-way, single and double solenoid, and 3 and 4-way air piloted valves
Valves available from 10/32 to ½ in. sizes and pressures of 0 to 150 psig
FRLs rated to 150 psig maximum input pressure in port sizes from 10/32 to 1 in. in standard or high flow rates
FRLs offered include stacking filter/ regulators, plus bowl, and drain option
Clippard Instrument Laboratory Inc.
Cincinnati, Ohio
(513) 521-4261
www.clippard.com/maximatic-msd
Circle 151
Pneumatic actuator
Pressurized air control (PAC) actuator II does not require system upgrades or special engine modifications for use in lawn and garden tools.
Features & benefits
3¾ in. stroke pulls in 100 lb in 2 sec
Smooth engagement eliminates severe shock loads
Requires ½ A vs. 5 to 10 A in electric clutch
Single button engagement for ease of use, troubleshooting, and maintenance
Noram
Milwaukee, Wis.
(414) 267-4000
www.noram-clutch.comCircle 152
