Design by objective: RESPONSE
Incremental shaft, hollowshaft encoders
The Kübler 2 in. incremental shaft (T8.5000) and hollowshaft (T8.5020) encoders offer extremely high shock ratings for continuous duty operation.
FEATURES & BENEFITS
- Shock rating of 250 g
- Speeds to 12,000 rev/min, frequency to 300 kHz
- Resolution to 3,600 pulse/rev
- Available with many output circuits, shaft and bore sizes; optional M12 eurofast quick disconnect
TURCK INC.
Minneapolis, Minn.
(800) 544-7769
www.turck.com
Circle 113
Airless cylinders
Multi-position airless cylinders achieve high speeds for precision through complete adjustable control of all movement parameters.
FEATURES & BENEFITS
- Loads to 22 lb
- Programmable for high stroke accuracies
- High acceleration and linear speed produce low cycle times
- Multiple end stop positions with accuracy of ± 0.1 mm provide high flexibility in part handling
IMI NORGREN
Littleton, Colo.
(303) 794-2611
www.norgren.com
Circle 114
Linear motor positioning actuator
Type GLM30 high force linear motor positioning actuator provides 3,000 N continuous linear force using liquid cooling.
FEATURES & BENEFITS
- Instantaneous peak-linear-force of 4,500 N
- LM Guide type SHS features long strokes and large thrusts
- Caged technology promotes reduced dust generation, low noise, high speeds without sacrificing accuracy
THK AMERICA INC.
Schaumburg, Ill.
(847) 310-1111
www.thk.com
Circle 115
Permanent magnet motors
PS Series motors feature permanent magnet rotors combined with an outer rotor design.
FEATURES & BENEFITS
- Resolution of more than 2.6 million counts/rev, maximum speed of 600 rpm, accuracy of 30 arc/sec, repeatability of 2 arc/sec
- Torque three times higher than other models in compact design
- Reduced setting time; reduced positioning time compared to other motors with 180° positioning move
NSK PRECISION AMERICA INC.
Addison, Ill.
(630) 620-8500
www.nskprecision.com
Circle 116
