New Product: Glass roving
S-1 glass rovings are high-performance reinforcements for thermoplastics. A 32% S-1-glass-filled thermoplastic performs the same as a 60% E-glass filled material. Using less fiber also provides better impact resistance, surface aesthetics, and process efficiency.
The S-1 fibers work with PC, PEI, PBT, and PA 6.6. The fibers have better hydrolytic stability, 30% higher tensile strength, and 18% higher tensile modulus than E-glass. The fillers come in roving and chopped-fiber forms.
AGY
2556 Wagener Rd.
Aiken, SC 29801
(888) 434-0945
http://www.agy.com/
