High-temperature structural epoxy - Master Bond Inc.
The epoxy bonds dissimilar substrates in electronics, aerospace, and other applications.
Supreme 46HT-2 two-component adhesive resists temperatures from -100°F to +500°F, thermal cycling, and shock and has good toughness, strength, durability, and electrical insulation.
The 100:30 mix-ratio epoxy cures at 250°F or higher and is not sensitive to minor changes in mix ratio. Non-drip version Supreme 46HT-2ND2 does not flow during cure. Both come in half-pint, pint, quart, 1-gal, and 5-gal container kits.
Master Bond Inc., 154 Hobart St., Hackensack, NJ 07601, (201) 343-8983, www.masterbond.com
Jessica Shapiro
