Tiny Photoelectrics
Oct. 7, 2004
The Minos line of subminiature photoelectric sensors feature the smallest distance adjustable true background suppression.
The sensors measure 8 3 10.8 3 16 mm, which is smaller than a keyboard key. With single-button teach-in and true background suppression by triangulation, the sensor detects regardless of color, texture, or reflectivity while simultaneously ignoring all background objects. An interference-resistant pulsed visible red light source gives the sensors a 60-mm sensing range in true-background-suppression versions and a 150-mm range in standard diffuse. Additional features are a response time of less than 500 m sec, multiple indicator LEDs, short-circuit and reverse-polarity protection, and a wide 10 to 30-Vdc supply range. The easily mountable Minos is offered in cable or M8 connector pigtail options. Applications include uses in semiconductor, printed-circuit board, packaging, textile, printing and graphics, assembly, robotics, and pharmaceutical industries.
Baumer Electric Ltd., 122 Spring St. C-6, Southington, CT 06489, (860) 621-2121, baumerelectric.com
July 17, 2024
July 10, 2024
Pumps Push the Boundaries of Low Temperature Technology
June 14, 2024
As an integral part of cryotechnology, KNF pumps facilitate scientific advances in cryostats, allowing them to push temperature boundaries and approach absolute zero.
The entire spectrum of drive technology
June 5, 2024
Read exciting stories about all aspects of maxon drive technology in our magazine.
