Rollers
How to Improve Wire Guide Roller Production with Cast Urethane
March 31, 2018
High-performance polyurethane can be engineered to produce more durable and consistent wire-cutting rollers to produce wafers.
The manufacturing of wafers for the microelectronics and photovoltaic industries involves a multitude of critical processes. One of the first of these is the precision cutting of ingots or crystals, typically composed of hard and brittle silicon, into uniformly sized wafers that are suitable for the processing of silicon chips.
In a production environment, this cutting is typically performed by multi-wire saws composed of diamond-coated wires precisely and evenly spaced in a belt-like configuration. The cutting of the ingot or crystal of silicon material is performed in one pass, resulting in dozens or even hundreds of wafers.
To achieve the ideal spacing between wires, as well as maintain the ideal wire tension, precisely manufactured rollers are used. This includes smaller “tensioner” rollers, along with a larger roller with machined notches that keep the diamond-coated wire in place.
Because the accuracy of the wafer cutting process is dependent on the durability and consistency of the rollers, those that lack material strength or precise geometry/dimensions can fail prematurely. This can lead to costly unplanned downtime, wasted materials, and potential delays in subsequent operations.
Fortunately, high-performance rollers are available that utilize unique, more durable, formulations of urethane and can be machined to meet the high tolerance requirements with consistency from part to part, thus ensuring the ideal multi-wire cuts.
High-performance rollers are available that use unique, more durable formulations of urethane.
Urethane Rollers
Most wire-cutting rollers in use today are composed of urethane (short for polyurethane). Shorter rollers, which typically cut up to 30 wafers simultaneously, are made of high-performance cast and machined urethane. The longer rollers, which often cut up to 300 wafers, are often coated with urethane sleeves having similar properties.
“Urethane is the preferred material for both long and short wire cutting rollers,” says Greg Cappaert, technical sales engineer at Argonics, one of the U.S.’s largest producers of wear-resistant urethane products. “Cast urethanes are tough, abrasion-resistant elastic materials that combine many of the performance advantages of high-tech plastics, metals, and ceramics, along with the resiliency and flexibility of rubber parts.”
Because urethane’s properties can be adjusted over wide ranges of hardness, resilience, spring rate, and dynamic properties, its versatility offers custom solutions to difficult design challenges. Below is a list of urethane’s physical properites:
  • Hardness: Polyurethanes can be formulated to cover a wide hardness range, from 20 Shore A to 85 Shore D. Most rubbers have a hardness that is typically found between 30 and 80 on the Shore A scale, and structural plastics begin at 55 on the D scale.
  • Abrasion Resistance: Abrasion or wear can occur in a variety of ways due to the stresses experienced through sliding action or high or low impingement wear. Polyurethanes have a high abrasion resistance and show a definite improvement in wear life over other materials in field and laboratory tests.
  • Stress and Strain: Polyurethane elastomers have high modulus, high tensile strength, and high elongation. This combination imparts toughness and durability to the cast urethane part.
  • Tear Strength: This is a measure of how well a material can withstand the effects of tearing. Due to the nature of their chemical composition, polyurethanes possess an advantage over conventional rubber materials.
  • Resilience: Resilience/Rebound is defined as the ratio of energy given up in recovery from deformation to the energy required to produce the deformation. Many urethane elastomers maintain their resilience with changing temperatures far better than other rubbers through the range from 32°F to 200°F.
  • Compression: Compression set is the characteristic of an elastomer to remain permanently deformed after deforming forces are removed. The lower the percentage, the better the material resists permanent deformation. Polyurethane has a low compression set.
  • Thermal Conductivity: This is defined as a measure of a material’s ability to transfer heat. It is the heat energy transferred per unit time and per unit surface area, divided by the temperature difference. Heat build-up in urethane parts occurs when a part is subjected to flexing or cycles of compression and tension. To avoid premature failure, one must select the proper polyurethane formulation, and in the proper part design, to counteract the effects of heat build-up.
The image above shows where different urethane rollers fall on the hardness scale.
“Urethane, even in relatively small quantity production, can be adapted and tailored to prioritize the physical properties that design engineers need,” says Cappaert.
Urethane’s properties are vital to high-volume production operations that utilize multi-wire saws to slice wafers as thin as 80-100 microns. Any deviation in wafer thickness or profile will bring a cutting operation to a halt and, unless spare rollers are on hand, create serious production delays.
Urethane rollers used on wafer wire-cutting equipment are consumable items. The shorter rollers, also known as tensioners or pulleys, are replaced several times a year. Longer rollers that have urethane linings must be recoated as much as 40-50 times annually.
Cappaert says that much of the turnover of rollers results from rollers falling out of spec prematurely due to shortcomings in urethane formulation, casting, or machining.
Because urethane is an engineered material, many problems can be overcome by adjusting formulation to meet the specific requirements of an application, as well as rigorous testing and stringent quality control of individual parts. He also notes that polyurethane rollers can be engineered to deliver extreme accuracy in both wet and dry operations, such as machined tolerances to ±0.004 in. (±0.10 mm).
Keeping an Eye on Maintenance
Urethane, even in relatively small quantity production, can be adapted and tailored to prioritize the physical properties that design engineers need. Rollers can be machined to meet the high tolerance requirements with consistency from part to part to ensure the ideal multi-wire cuts.
The production of cast urethane rollers is complex and highly sensitive. Machine maintenance needs to regularly schedule and machines should be individually inspected. When larger urethane-coated rollers are approaching wear limits, these must be stripped and re-coated using the same types of stringent procedures.
Although specific customer formulations and design information are considered proprietary, Cappaert says these methodologies can lead to improvements in wafer warp, consistency of cut, and thickness variation, while also increasing roller longevity.
Another difficulty that many suppliers and users of precision wire cutting equipment can relate to is supply chain issues. Depending on inventories on hand, untimely deliveries of urethane rollers—possibly due to premature failures—can shut down wafer cutting, resulting in costly delays down the rest of the production line. Working closely with the manufacturer will help solve most these issues.
June 25, 2025
June 25, 2025
In this insightful on-demand webinar, discover the latest trends and gain expert-driven solutions to today's robotic actuation challenges.
June 25, 2025
maxon drive systems are among the most flown drives in space research, and in space they power some of the most complex robotic systems that humans have ever built.
