Compact Motion Controller
The EPOS 24/1 digital motion controller works in position, velocity, and current mode.
June 3, 2004
COMPACT MOTION CONTROLLER
Available in two versions for brush or brushless motors, its small package size makes the device a candidate for controlling small motors. Dimensions are 55 3 40 3 25 mm (2.2 3 1.6 3 1 in.) and weight is 45 gm (1.6 oz). Communication is via RS-232 or CANopen. Working from 9 to 24 Vdc, the controller is capable of 1-A max continuous current and 2-A peak current. Efficiency is up to 85%. A 50-kHz switching frequency and built-in choke ensures compatibility with most low-inductance motors, while the sinusoidal commutation for brushless motors ensures minimal torque ripple and low noise. Maximum motor speed is 25,000 rpm for two-pole motors. Maximum encoder input frequency is 1 MHz. The controller accepts six digital inputs and two analog inputs, and has two digital outputs.
Maxon Precision Motors Inc.,
838 Mitten Rd., Burlingame, CA 94010,
(800) 865-7540,
www.maxonmotorusa.com
