Polyurethane hoses
Aug. 2, 2013
The 83FR DuraGard nonconductive, weld-spatter-resistant polyurethane hose is suited for robotic-assembly applications. Ultralite superbraid polyurethane air hose is 29% lighter than equivalent thermoplastic air hoses and 63% lighter than rubber.  The compact hoses offer an extremely tight bend radius without reducing the flow of media traveling through the core tube.
The 83FR DuraGard nonconductive, weld-spatter-resistant polyurethane hose is suited for robotic-assembly applications. Ultralite superbraid polyurethane air hose is 29% lighter than equivalent thermoplastic air hoses and 63% lighter than rubber.  The compact hoses offer an extremely tight bend radius without reducing the flow of media traveling through the core tube. The polyurethane hoses come with permanent fittings or convenient push-on fittings.  The UltraLite hose uses a strain relief that lets the hose bend freely without kinking at the fitting.  Standard sizes range from ¼ to ¾-in. ID.Parker Hannifin Corp., Parflex Div., 4700 Lone Star Blvd., Fort Worth, TX  76106, (817) 984-0135, www.parker.com
