Stainless Steel Now an Option for Quarter-Turn Fasteners
Feb. 5, 2015
The Southco DZUS D8 PANEX range of quarter-turn fasteners has been expanded to include stainless-steel fasteners that have the same ease for installation as the standard models, but offer vibration-resistant fastening and resistance to heat and corrosion for outdoor applications.
The formed AISI/SAE 300 stainless steel increases the fasteners’ total material thickness (TMT) tolerance for robust fastening. They are available in size 6 with slotted, hex, and Phillips recessed heads, and mini clip-on and rivet-on receptacles are available optional features.
Southco, P.O. Box 0116, 210 N. Brinton Lake Rd., Concordville, PA 19331-0116; (610) 459-4000; [email protected]
Discover how pump motor parameterization provides unprecedented control capabilities, allowing KNF to tailor pumps to your exact needs for increased productivity, extended pump...
July 28, 2025
Ensure accuracy and reliability in your lab. Discover how KNF's advanced food testing equipment provides the precision you need for critical analysis and results.
July 28, 2025
Explore the vital role of KNF pumps in cutting-edge fuel cell technology. Learn how our innovative solutions contribute to efficient and reliable energy systems.
July 28, 2025
Unlock optimal pump efficiency by understanding suction height. This essential guide explains how to prevent common issues and ensure peak performance for your applications.
