Insidepenton Com Electronic Design Adobe Pdf Logo Tiny
Fundamentals of Annular Snap-Fit Joints
Jan. 6, 2005
Annular snap fits aren't well understood but can be a handy means of making assemblies easily disassembled or permanently joined together.
Snap-fit joints are the most widely used way of joining and assembling plastics. They are classified according to their spring element and by separability of the joint: Will it be detachable, difficult to disassemble, or permanent? The most common snap fit is the cantilever. It is based on a flexural beam principle where the retaining force is a function of the material's bending stiffness. The second most widely used is the torsional snap joint. Deflection comes from torsional deformation of the joint's fulcrum and shear stresses carry the load after assembly.
But perhaps the least understood type is the annular snap joint (ASJ). Classic examples of ASJs include ballpoint pens with snap-on caps, and the child-resistant cap on Tylenol bottles. This type of snap fit is best for assembling axis-symmetrical (cylindrical) profiles. But ASJs are often good choices for compact, stiff joints even if the part is not annular.
ASJs are generally stronger, but need greater assembly force than their cantilevered counterparts.
ASJs are basically interference rings. The smaller-diameter male component (plug) has a bump or ridge feature around its circumference. The ridge diameter is slightly larger than the inside diameter of the mating tube-shaped female hub. Key to ASJ operation is to make the plug from a more rigid material than its mating female hub. Then the ridge will deflect the hub outward. Deflection imposes a relatively high onceonly or repeated short-term load (hoop stress) distributed along the axis of the hub as the plug slides into it. The ridge feature engages into an undercut grove molded into the inside diameter of the hub, at which point the assembly returns to a stress-free condition.
The maximum permissible deformation of the hub, P, is limited by the maximum permissible strain or proportional limit of the material. This limit is typically 50% of the strain at break for most reinforced plastics (safety factor of two). It can be upwards of 60 to 70% of strain at break for more elastic polymers assuming the appropriate safety factor.
The geometry of the ridge determines the assembly force, F, needed to engage the snap joint and whether or not the annular snap joint will be detachable or permanent. The lead angle, , is generally < 30°. Its corresponding return angle,, determines assembly separability. A shallow return angle (30°) easily separates, a 90° angle is permanent, and a 45° angle is typical of most applications that disassemble.
Returning to the example of the Tylenol bottle, one can see that the ridge profile has a 90° return angle. This in principal should make the cap impossible to remove from the bottle. The packaging designer employed a clever trick, explains design engineer Mark Wichmann of DuPont to transform a permanent snap joint into one that easily disengages. "The trick," he says, "is notches molded into the ridge on the bottle. This intentional breach in the snap fit, under the right orientation (arrows lined up), lets the cap pop easily off."
Despite the prolific use of snap-fit joints in every conceivable configuration for plastic assemblies, says Wichmann, designers often shy away from annular snap fits for two reasons. The first is ASJs are generally harder to mold and require more complex tooling than cantilevered versions.
The second is material. Stress is a material's response to distortion. For any given uniaxial distortion (strain, ) the stress response is given by the appropriate stress-strain curve. Stiffer, reinforced plastics don't recover as easily from deformation and will need engagement features ( undercuts and ridges) that are quite small so the plastic doesn't stretch beyond its elongation limit in the hoop direction, says Wichmann.
In an annular snap fit, the hoop-direction distortion (strain) required of a hub when inserting a press-fit plug is a matter of the geometric interference. This required strain may be compared to the allowable strain of a material. Or it may be converted to how the material responds to the strain, its hoop stress, and then compared to the material's allowable stress. Hoop stress is a tensile stress for the female hub and a compressive stress for the male plug. If the joint stresses the material beyond its proportional limit, the plastic may stress-craze or crack causing the joint to fail.
WHEN ANNULAR SNAP FITS MAKE SENSE
It doesn't take an FEA Pro or an engineering Ph.D. to find out whether or not annular snap fits can handle a particular application, says Wichmann. Instead, he suggests making a first order approximation using tried and true handbook calculations and a few basic assumptions.
"Although it's a powerful design tool, a thorough, nonlinear FEA simulation (with contact elements) is time consuming and certainly not trivial for snap fits," says Wichmann. "Using simple handbook equations, it's possible, however, to calculate reasonably close approximations, often within 90 to 95% of an FEA analysis. The resulting ballpark, first-order approximation, is often enough for a working prototype. The prototype in turn gives feedback on fit, function, and resulting assembly/disassembly forces needed.
For example, designers of a recent motor application wanted to employ an annular snap-fit connection between the encapsulated stator and motor housing. The first order of business, says Wichmann, was getting the motor designers to not worry about every conceivable material property that may affect assembly forces and other loads. Often, it's best to first make a few critical assumptions to see if the part geometry and material will handle an annular snap fit before going through lengthy FEA calculations.
The first step was determining the necessary safety factor for the assembly. The engineers determined a safety factor of two was reasonable for the motor. Their thinking was the components would be assembled in a carefully controlled and fixtured assembly process. There would be no repeated disassembly, and no one's life would be at stake if the snap fit failed.
Next, came an evaluation of material and geometry compatibility. Two approaches are possible, says Wichmann. "One is to first establish a particular geometry and then find a material which survives the deflection force (i.e., strain of assembly, P). In this case, the encapsulated stator slipped inside the motor mount, deflecting the annular snap joint in the process." The permissible deflection depends on the permissible strain for the material. Amorphous materials such as polycarbonate, polystyrene, PC/ABS, and ABS can be strained up to 70% of the yield strain during a single brief snap fit, he says. "Reinforced materials such as those the motor designers were evaluating are less forgiving. So you would use the rule of thumb — 50% strain at break (safety factor 2) — to make a reasonable material evaluation."
The second approach starts with a material rather than a geometry. "This will give a known permissible strain (i.e., 50% strain at break). The geometry can then be tweaked to meet the permissible strain constraints," explains Wichmann. In the case of the motor, the geometry was the inside diameter of the female hub and the outside diameter of the male (stator) part plus ridge height.
For the motor, the designers opted for the first method and initially defined the annular snap geometry. Next they assumed that all the deflection would come entirely from the motor mount housing. Then the deflection force or strain of assembly of the annular snap fit can be estimated from the geometry of each component. Minimum inside diameter of motor mount housing was 64.5 mm. Maximum outside diameter of stator was 66 mm with a 3-mm ridge or hook.
The percent strain the motor-mount housing will see can be estimated by taking the ratio:
where DS = the outside diameter of the stator (66 mm) and DH = the inside diameter of the motor mount housing (64.5 mm). The result, 2.3% strain, is a first-order approximation that is best for membrane stresses when the wall thickness is < 0.1 the nominal diameter. For the motor, wall thickness was 2.5 mm, which is less than 0.1 66 = 6.6 mm so the approximation is reasonable.
The next step in the approximation is to see whether the candidate polymer for the motormount housing, DuPont's Hytrel 8238 ( generalpurpose thermoplastic polyester), can survive the expected deflection stress at the predicted 2.3% strain.
From the stress-strain curve for Hytrel 8238, the expected deflection stress at the predicted 2.3% strain is about 22.8 MPa (3,300 psi). Comparing this value to Hytrel 8283 material property data shows it is less than the strain at break of 48.3 MPa (7,000 psi) and appears to be below the onset of significant plastic yield, the knee of the S/S curve. The SS curve reveals that the 2.3% strain value is below the significant transition (yield) at 32.4 MPa (4,700 psi). It is important that the force of assembly not exceed this value.
This quick first-order approximation showed the designers that the annular snap geometry and the material were compatible. Thus the annular snap fit would have a good probability of not failing when it engaged.
ASSEMBLY FORCE ESTIMATES
With geometry and material defined, the next step is to estimate the assembly force to engage the snap fit. This employs a few basic handbook calculations similar to those for analyzing cantilever snap fit assembly forces.
The force needed to assemble an annular snap fit is a function of two elements: the force to expand or deflect the hub outward, and the frictional force between the plug and the hub during assembly.
An annular snap groove close to the end of the hub will have a different deflection force (P) than one remote from the end. As a rule, designers typically choose to place the groove in the hub close to the end, as was the case with the motor design. A groove is considered remote from the end of the hub when:
where = distance of the groove from the end of the hub, d = inside diameter of the hub, and t = hub wall thickness that will deflect under load. This relationship constitutes a simplification, assuming a constant strain through the wall thickness (which is not actually the case). Due to this dissimilar tangential hoop stressing, P for a snap-groove remote from the end is three times that of one close to the end.
The following equation calculates P close to the end:
where f = deflection distance, in this case 1.5 mm, X = a geometry factor, and Es = Hytrel 8283 secant modulus in MPa. Using the calculation for the Hytrel's permissible deflection stress (22.8 MPa) at 2.3% strain, Es is approximately (22.8 MPa/0.023) or 991 MPa.
The geometry factor, X, must be divided into two equations based on the flexibility or rigidity of the mating parts. When the outer mating female hub is flexible and the inner (male) plug is rigid X = XN. If the hub is rigid and the plug flexible then X =XW. The values for XN and XW are calculated from:
where da = outside diameter of the flexible hub, mm; d = outside diameter of the rigid plug, mm; di = inside diameter of the plug when the plug is flexible and the female hub is rigid, mm; and = Poisson's ratio for the Hytrel 8283 and is equal to 0.45.
For the motor design, the hub (Hytrel motor housing) was flexible and the plug or stator was rigid. The stator was from a 15% glass-reinforced polyethylene terephthalate, Rynite 415HP, also from DuPont. Additionally, the hub deflects a distance f equal the height of the ridge and is equal to 1.5 mm.
When d = 66 mm and da = 71 mm, the value of X = XN and P are
and
Motor designers wanted to use an assembly fixture and about 300 lbf of force to assemble the motor. The geometry and selected materials led to calculating the force of assembly F as follows:
= coefficient of friction and = lead angle. For the motor design, the lead angle on the stator was 35° and the coefficient of friction between the Hytrel and Rynite is about 0.45.
From the Diagram of coefficient of friction and lead-angle interaction, the value of
is about 1.68 and the resulting force of assembly is 1,384 N or 311 lbf.
Discover how pump motor parameterization provides unprecedented control capabilities, allowing KNF to tailor pumps to your exact needs for increased productivity, extended pump...
July 28, 2025
Ensure accuracy and reliability in your lab. Discover how KNF's advanced food testing equipment provides the precision you need for critical analysis and results.
July 28, 2025
Explore the vital role of KNF pumps in cutting-edge fuel cell technology. Learn how our innovative solutions contribute to efficient and reliable energy systems.
July 28, 2025
Unlock optimal pump efficiency by understanding suction height. This essential guide explains how to prevent common issues and ensure peak performance for your applications.
