What’s the Difference Between Rigid-Coupling Types? (.PDF Download)
Dec. 7, 2015
Couplings transfer power by connecting two shafts at the ends to transmit torque. While there are six degrees of freedom (DOF) to a shaft, coupling applications are only concerned with four—axial, angular, parallel, and torsional. Misalignment in any of these directions will cause balancing and vibration problems that can lead to shutdowns and damage. It will also greatly increase wear on multiple parts, such as the bearings. Making sure a motor is properly aligned can take experience and time, which may also not be ideal...
Register or Sign in below to download the full article in .PDF format, including high-resolution graphics and schematics when applicable.
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
