Conveyor pulley
Sept. 12, 2013
Dodge D-LAG conveyor pulleys use a cutting-edge natural rubber compound that is 73% more resistant to wear than standard SBR rubber. The pulleys will extend the operating life of both the conveyor pulley and conveyor belt. The lagging is 100% vulcanized for pulley bonding and strength, making it resist cuts and gouges. Two pulley styles are available: D-LAG heavy-duty drum pulleys from 10 to 24-in. diameter, and D-LAG MDX (mine-duty extra) drum pulleys from 12 to 24-in. diameter. The heavy-duty pulleys are designed with flexible end discs to eliminate weld fatigue under cyclical loads, while the MDX style features an integral hub design that eliminates the welded hub.Baldor Electric Co., 5711 R.S. Boreham, Jr. St., Fort Smith, AR 72901, (479) 646-4711, www.baldor.com
