Essential Equipment for Your Filament-Based 3D Printer (.PDF Download)
3D printers require a lot of support. They need gadgets and tools and of course, consumables. If you are using a fused deposition type of printer, the type that uses spools of filament, then there are a few essentials that you must procure for your toolbox. The items listed below are indispensable. Without them, you will be struggling and very likely using the wrong tool the job...
Register or Sign in below to download the full article in .PDF format, including high-resolution graphics and schematics when applicable.
