Items to Consider when Choosing Shaft Misalignment Couplings
Oct. 24, 2013
Sponsored by Ondrives
Do you have drive components that need to be coupled to driven components? Chances are you need a coupling. Rigid couplings cause problems more often than they solve them because two shafts are almost never perfectly aligned. Enter misalignment couplings: they transmit torque while absorbing the misalignment between your components. This white paper goes over important items to consider when choosing couplings for your system.Download Now
