Flexible VFD Cable
V-Flex cable is designed for variable-frequency drives (VFD).
July 20, 2012
V-Flex cable is designed for variable-frequency drives (VFD). The cables feature both UL and CSA tray-cable ratings, a low-temperature rating of –40°C, and a bend radius that is 5× that of standard VFD cable.
Cross-linked polyethylene insulation offers resistance from corona discharge and low capacitance for longer runs. A TPE jacket resists everything from corroding solvents (UL Oil Res I/II) to intense sunlight. The 5× static bend radius lets V-Flex fit in tight corners.
The V-Flex cable comes in sizes from 16 to 4 awg, with a temperature range of –40 to 90°C. The cables’ double shielding system (a combination of aluminum/polyester/aluminum foil and copper braid with 85% coverage) protects against EMI over a wide frequency range.
Alpha Wire
711 Lidgerwood Ave.
Elizabeth, NJ 07207
(800) 522-5742
© 2012 Penton Media, Inc.
