Fun with Fundamentals Puzzler: Shell Shocker
Jan. 1, 2007
Wurme gets to his stand early on opening day, initiating a new era of hunting. He fires up his generator and tunes it to 40 A. If the slug shooter is based on conventional railgun design, how far can he reach with each shot?
See the previous problem: Gone to the dogs.
Finagle J. Wurme has missed deer season again. For the tenth straight year, his boss at Charlie's Diner wouldn't give him time off. Randy, the cook, claimed bow season. Andy, the cashier, took gun season, and the new hostess, Sandy, blocked off all the days during muzzle loading for cosmetic surgery.
Determined to hunt and aided by a loophole in the local county code, Wurme establishes an auxiliary season for electric sporting arms. Using an old rifle stock, some jumper cables, and wire hangers, he concocts a device that would make Horace Smith and Daniel B. Wesson howl.
Assume the rails are 5 cm apart and that they generate a magnetic field of 5 Tesla.
Assume the horizontal acceleration Ax is assigned a value of 1,000 m/sec2 when the projectile is still within the gun. (Once it's left the gun, well ... think about it ...)
Assume the rail is about 1 m long.
Hint: You can the equation X = Xo + Vxo·T + 0.5·Ax·T2 to describe the system.
Okay, I've had enough. Give me the solution.
Elisabeth Eitel
Discover how pump motor parameterization provides unprecedented control capabilities, allowing KNF to tailor pumps to your exact needs for increased productivity, extended pump...
July 28, 2025
Ensure accuracy and reliability in your lab. Discover how KNF's advanced food testing equipment provides the precision you need for critical analysis and results.
July 28, 2025
Explore the vital role of KNF pumps in cutting-edge fuel cell technology. Learn how our innovative solutions contribute to efficient and reliable energy systems.
July 28, 2025
Unlock optimal pump efficiency by understanding suction height. This essential guide explains how to prevent common issues and ensure peak performance for your applications.
