Engineering Design Problem, Plastic Bearings are a Cost Effective Solution
Plastic bearings continue to displace metal bearings in many applications. They are a cost effective solution that provides efficient, smooth, quiet operation with less maintenance than metal bearings. Learn the benefits of using a plastic bearing in your design in this informative guide from QBC – Quality Bearings & Components
