Axial-piston pump
The V60N-130 joins the V60N Series of axial-piston pumps. The Series now consists of four different sizes with displacement volumes up to 8 in.3/rev, working pressures of up to 5,800 psi, and peak pressures of up to 6,500 psi. All pumps have swash plates and provide required displacement volume without over or underdimensioning the pump output.
The V60N-130, designed for high pressure and high volume, directly attaches to a vehicle’s power take-off with an SAE flange. The pump comes with a wide variety of controls and flanges with options for connecting additional pumps to the through shaft.
Axial piston pumps are suitable for construction machines, concrete pumps, public transport and utility vehicles, waste-disposal trucks, cranes, forestry vehicles, as well as many other machines.
Hawe North America Inc., 9009-K Perimeter Woods Dr., Charlotte, NC 28216, (704) 509-1599,
www.hawehydraulics.com
