Compact Modular Switches Target High/Low-Pressure Hydraulics
Feb. 9, 2015
Omega released PSW8, a new series of compact modular pressure switches for stationary and mobile hydraulic applications. Switches for low-pressure applications feature diaphragm pressure switches, while high-pressure switches have a compact piston design. An increase in pressure above the set-point activates the single-pole, double-throw (SPDT) micro switch and resets as the pressure returns below the set-point. The set-point can be adjusted with a screw on the switch. Switch contacts are gold or silver for different currents and voltage. Gold-plated contacts are rated for 0.1 A at 125 V ac and 0.01 A at 30 V dc, and silver contacts are rated for 3 A at 250 V ac, 5 V at 120 V ac, or 0.4 A at 120 V dc.
For more information about the new range and combinations of features, see the specification sheet.
Omega, One Omega Drive, Stamford, CT 06907, 1 (800) TC-OMEGA
Leah Scully
Associate Content Producer
Leah Scully is a graduate of The College of New Jersey. She has a BS degree in Biomedical Engineering with a mechanical specialization. Leah is responsible for Machine Design’s news items that cover industry trends, research, and applied science and engineering, along with product galleries. Visit her on Facebook, or view her profile on LinkedIn.
