Steel bellows coupling
The backlash-free primeflex coupling can be plugged in for easy installation and disassembly
The backlash-free primeflex coupling can be plugged in for easy installation and disassembly.
Features & benefits
  • Can be dismantled safely without putting the steel bellows at risk, even after long operating periods
  • Mounts easily to shafts via clamping or shrink disk connections
  • Compensates for axial, radial, and angular shaft misalignments
  • Torque transmitted with frictional locking or frictional and positive locking
Mayr Corp. (201) 445-7210 www.mayrcorp.com
