Belts and planetary gearboxes add up to reliable parts-handling
Conventional wisdom says that heavy-duty parts handlers need ball screw or rack-and-pinion actuators.
Conventional wisdom says that heavy-duty parts handlers need ball screw or rack-and-pinion actuators. But this builder uses belt drives to prove otherwise.
View Article
