Pneumatics and aerodynamics could boost tractor-trailer fuel efficiency
The aerodynamic improvements produced by geometry changes, which generate fuel savings of as much as 7%, involve rounding aft trailer corners, installing fairings, and making other changes that smooth airflow over the boxy trailers. Fuel savings of an additional 5% come from pneumatic devices that blow air from slots at the rear of the trailer to further improve and prevent separation of airflow. Recent tests done using a full-size tractor-trailer truck show the techniques could boost fuel economy by as much as 12%. The improvements could also enhance braking and directional control, potentially improving safety for the big vehicles. The tests are based on systems originally developed for jet-aircraft wings.
"Aerodynamically, we have resolved unknowns raised in earlier testing, and the next step is to get this into a fleet of trucks for more extensive testing," said Robert Englar, principal research engineer in the Aerospace, Transportation and Advanced Systems Laboratory of the Georgia Tech Research Institute (GTRI).
Englar's research team worked with Volvo Trucks of North America and Great Dane Trailers, the manufacturers of the basic tractor and trailer, respectively, to install the new aerodynamic features and blowing system at the rear of the trailer. A series of higher-speed test runs at the Transportation Research Center's Ohio fuel-economy test track in September demonstrated the fuel savings that had been expected.
The tests involved operating a blowing-equipped test tractor-trailer for several different 45-mile runs around a 7.5-mile oval at highway speeds of 65 and 75 mph. A control truck that did not have the aerodynamic improvements or pneumatic-control system was operated under the same conditions for a comparison. As an additional control, the test truck was also run without the experimental blowing equipment.
Before the pneumatic control system can be widely used in trucks, however, researchers will have to choose the best source of compressed air for the blowing system, Englar notes. Options include a diesel-powered motor installed in the trailer like current refrigeration units, bleeding pressurized air from the truck's supercharger, or a simple chain drive to turn air blowers from the trailer's wheels.
Aerodynamic drag becomes dominant only at higher speeds, so the blowing would be turned off when the trucks were idling or operating at low speeds.
To fully assess the energy savings, the researchers will have to accurately account for the power needed by the blowing system, which will cut into the fuel savings. And other practical issues, such as protecting the pneumatic surfaces from damage during docking, still must be resolved, though that effort is already underway.
Beyond boosting fuel efficiency, the pneumatic system can also provide a form of aerodynamic braking to assist the mechanical brakes. "Using the pneumatic systems, you can turn a lowdrag configuration into a high-drag configuration in a very rapidly, giving you a lot more braking power," Englar said.
Differential blowing could also improve control of trailers in crosswinds by helping compensate for the wind direction. "This would allow you to have the blown equivalent of an airplane rudder on the trailer, without any physical additions," he explained. "Beyond increasing fuel efficiency, the pneumatic system could be a drag reducer, drag increaser, safety factor and a stabilizing device."
Both the improved braking and directional control could be part of an automated system that would not require special attention from drivers.
Further energy savings could come using a pulsed pneumatic system, which preliminary wind-tunnel studies on wings have shown could produce the same aerodynamic efficiency with less energy consumed by the blowing system. Englar hopes to get further funding to study how this might affect the truck aerodynamics as well as fuel consumption. The suspicion is that pulsed blowing could reduce the blowing system's fuel requirements by about half to three-quarters. This would reduce the penalty for running this kind of a blown system.
