Machine Design
  • Resources
  • Members
  • Directory
  • Webinars
  • WISE
  • CAD Models
  • Advertise
    • Search
  • 3D Printing & CAD
  • AUTOMATION & IIOT
  • Robotics
  • Motion Systems
  • Materials
  • Video
  • Data Sheets
  • Topics
    Industry Markets3D Printing & CADAutomation & IIoTFastening & JoiningMaterialsMechanical & Motion Systems Medical DesignRobotics
    Resources
    Machine Design ResourcesWISE (Workers in Science & Engineering)Company DirectorySearch Data SheetsContributeDigital Edition ArchivesCSIA Exchange
    Members
    ContentBenefitsSubscribe
    Advertise
    https://www.youtube.com/channel/UCXKEiQ9dob20rIqTA7ONfJg
    1. News
    Precision Controller Gives Engraver Artisan-like Craftsmanship
    Sept. 8, 2009
    A machine capable of mimicking the craftsmanship of hand-engraving uses a four-axis motion controller for its precision movements.
    Leland Teschler
    Resources:
    Galil Motion Control,www.galilmc.com
    Galil DMC-21x3 motion controller, www.galilmc.com/products/dmc-21x3.php
    The Artesà machine in action, as well as video of a manual engraving by artisan for comparison, www.artesa-nc.com/ENG/videos.php
    A machine that mimics the craftsmanship of hand engraving uses a four-axis motion controller for precision movements.
    Artesà, a company in Barcelona, Spain, developed an engraving machine which employs four stepping motors driven by a DMC-2143 four-axis Ethernet motion controller from Galil Motion Control, Rocklin, Calif. Artesà’s goal was to build a machine that could replicate hand engraving. And the tough part about mimicking hand-engraving work is that artisans perform a downward and upward movement with the chisel for each cut. Artesà’s machine synthesizes this action via a curvilinear or open polygonal trajectory in the vertical plane using nonrotating cutting tools.
    The engraver consists of a table with a bed frame firmly holding the workpiece. A spindle-mounted engraving-tool head which includes a laser pointer and three carbide inserts with 35, 90, and 135° corner cutting edges is suspended above the table.
    The motion controller controls the critical PT (line-depth) and SV (vector-tracing) axes. The PT axis gradually moves the cutting tool downward on a vertical plane so it can cut into the material to a desired depth on the descending part of the curve, and then moves it upward to the material surface, cutting the ascending part of the curve. The SV axis manages the 360° motion of the cutting tool, making sure the cutting edge always faces the programmed direction. Positioning accuracy is 0.1 mm/300 mm (0.004 in./12 in.) repeatable to 0.02 mm (0.0008 in.), under no-load conditions.
    Continue Reading
    Edge Computing & Gaining Value
    eBook: Linear Motion Control Strategies
    Smart Factory Solutions that Connect and Protect from Amphenol RF
    Nov. 28, 2023
    Stay Connected and In Control of Your Future Factories with Littelfuse
    Nov. 28, 2023
    Turn to NKK Switches for the Widest Range of Industrial-Savvy Electromechanical Switches
    Nov. 28, 2023
    Unlocking Operational Flexibility in Manufacturing with Industria IoT
    Nov. 28, 2023
    I already have an account
    New
    Heavy-Duty Collaborative Palletizing System Addresses Potato Industry’s Labor Shortages
    Future-Proofing Manufacturing with 3D Printing
    5 For Friday: Salary Survey Optimism; A New (and Important) Acronym; and Ways to Unleash the Potential of Design
    Most Read
    How Much Should a Bolted Joint be Tightened?
    Engineering Potential: What Determines Success?
    AI: Unleashing the Power in Manufacturing
    Sponsored
    Bourns Stifles Surges, Diminishes Downtime and Protects Parts
    Schmersal on Machine Safety: Manual Reset
    Schmersal Product Demo: SLC BLE
    Machine Design
    • About Us
    • Contact Us
    • Advertise
    • Do Not Sell or Share
    • Privacy & Cookie Policy
    • Terms of Service
    © 2023 Endeavor Business Media, LLC. All rights reserved.
    Endeavor Business Media Logo
