The EasySwitch HEPA Wet-Dry Vac simplifies the filter change process when switching from vacuuming a dry material to a liquid or vice versa. Utilizing minimal compressed air, the EasySwitch is a powerful pneumatic vacuum that can be used for any type or all kinds of environments. The EasySwitch vacuum uses a HEPA certified filter when vacuuming dry material.
By releasing one latch, removing the filter element and securing the latch, the vacuum can be converted for wet use. Reinstall the filter into the lid assembly for use with dry materials. The 55-gallon drum operates at just 79 decibels. Because the vacuum generator has no moving parts and uses no electricity, there is less concern for failed parts, motor failure or working with liquids associated with electric industrial vacuums.
