WAGO’s new IP67 rated I/O-Link analog converters offer a solid and cost-effective solution for incorporating conventional analog sensors and actuators with I/O-Link communications.
The 765-2702/200-000 has two 0-10 VDC inputs that are converted to I/O-Link for monitoring field level sensors. The 765-2703/200-000 has two 4-20ma analog outputs while the 765-2704/200-000 has two 0-10 VDC analog outputs. Both devices will convert I/O-Link signals to analog outputs and all of these devices can be set up using I/O-Link configuration tools such as WAGO’s I/O-Link configurator software.
These devices are ideal for new systems as they take advantage of the benefits offered by I/O-link. Users who wish to update older systems to digital communications can also leverage these compact IP67 devices.
